Circa 1960 Craftsman Drill Press Depth S
Any ideas on where I might go to find a depth stop for a circa 1960s Craftsman floor model Drill Press?
Do you need the threaded rod and stop nuts? Grizzly carries them in their catalogue.I believe it is 1/2x 20 right hand thread.
mike
I'll give Grizzly a try but I need the whole set-up. Don't even know if it had one to start. Wasn't too smart lugging in from an older friends garage without checking this first. He can't recall now, as he was not a big user of it (inherited it from his father!). Thanks for the reply.
There has to be a yoke that fits around the quill in order to install a depth stop. If the yoke is missing or there isn't a way to fasten one you can't install a depth stop.From my experience the older drill presses had both a depth stop and a quill lock. Have you tried the manufacturers yet. Worse comes to worse you could put a stop collar on your bits.
good luck , mike
Thanks, again. Tried Sears/Craftsman, no luck. This weekend, I'm going to check out the same vintage Atlas benchtop model that I switched from my home location to another site to see if I can fashion up a similar yoke/threaded rod/stop-nut. As I said, wasn't too smart switching it out (heavy buggers!) before I thoroughly checked out what I had on my hands (actually should have checked it out before I had it on my hands!). While I'm partial to trying to salvage old, reliable heavy-duty machines such as this one, maybe the best thing to come of it all, after the heavy lifting, is the acquisition of the free Grizzly catalogue which I browsed last night...516 pages of browsing may keep me busy over the holidays, and maybe I'll just find an equally reliable newer model with some up-to-date features (the Atlas benchtop also had an easy-access red/black on/off switch...this one has a small toggle switch located on the back of the machine up at the motor!). Happy holidays!
