I need an adjustable circle cutting jig for routers. What design is best?
I see no posters.. I'd say whatever gives you a good radius..
Any stick with a pin in the center attached to the router will do!
Only problem is you have to attach something in the center that makes a hole!
thanks will,Bob D.
Finewood,
There was an article in FWW 177 June 2005 by Yeung Chan that had a pretty slick circle jig.
Eric"When it comes time to die, make sure all you have to do is die." -Jim Elliot
THANKS
Aloha,
After years of struggling along with my shop built jig, I finally broke down and bought a "Lewin router compass" from Woodworker's Supply. What a difference! Easy to adjust and accurate.
THANKS
This one will cut precise holes from 4-12" @ 2" increments.More pix if you want to make at the 621 link.
tHANKS
"Router Magic" by Bill Hylton has plans for an excellent jig. I built it several years ago and cut precise circles and arcs ranging from a couple of inches to several feet on a regular basis.
Many thanks,sometimes a simple thing done correctly can save a lot of trouble. fINEWOOD
