Circular saw – safety & terms -good site
All,
I was browsing through another forum and came across the following site. Thought that it was worthwhile letting you all know about it too.
http://www.millard.demon.co.uk/circularsawbenches/sawsafetyindex.htm
Covers most of the recent discussions re tablesaws here as well as a bit more.
What are your thoughts, any agreement/disagreement with his suggestions/methods or anything else?
Cheers, eddie
Edited 10/13/2002 6:46:05 AM ET by eddie (aust)
Thanks Eddie,
Interesting and good info, but some of the phrases are a mystery ( the difference between British English and the American variety, no doubt)
For instance: "The gullets cannot adequately clear themselves of chippings. There is a risk of overheating when the saw loses its tension, becomes drunk and binds in the cut, leading to a kickback.The gullets cannot adequately clear themselves of chippings. There is a risk of overheating when the saw loses its tension, becomes drunk and binds in the cut, leading to a kickback."
Can explain how a tablesaw becomes drunk? :-)
Peter
Peter,
The drunkenness they refer to is not something I've seen in small saws, but I have seen it in large circular saws (20"+). I believe they use the word drunk to describe the manner in which the saw begins to "sway" as it heats up and the tension begins to change. When the tension in the blade begins to change, the saw starts to "wander"in the cut. It's not unlike the way a piece of steel will curl when it's heated, and when it cools. If you ever seen it happen to a running saw, you'll be glad to never witness it again because it's just plain frightening and, of course, dangerous.
Edited 10/13/2002 10:26:15 AM ET by Jeff K
The drunkenness they refer to is [used] to describe the manner in which the saw begins to "sway" as it heats up and the tension begins to change.
That would be my guess, too; kinda like not being able to walk a straight line, I guess.". . .and only the stump or fishy part of him remained."
Green Gables: A Contemplative Companion to Fujino Township
"drunk" is a useful English adjective for anything out of straight -- thus a brick wall can be 'drunk' (although the more common term for that is 'plssed', bricklayers being what they are)
Thanks for the English lesson.
Sounds like something I hope I never see!
Peter
