My miter gauge has a vertical hole, threaded, right behind the fence. At first I thought it was for a handle, but there’s not enough room for fingers.
Is the hole for a jig to keep the wood from sliding? That would be useful, but I haven’t found any such tool in online catalogs.
Janet
Janet,
Most people take the 'spare rods' that came with their router and put a thread on them to go in that hole...lol..(just being a smarty pants and waiting for the kids to wake up) Merry Christmas
It's for a miter gage clamp set. Delta sells one for about $35.
Follow this link: http://www.amazon.com/exec/obidos/tg/stores/detail/-/hi/B0000223EB/qid=1040943282/sr=1-1/ref=sr_1_1_etk-tools/104-7405195-2542367
Where could I get the parts to make a clamp like this?
hi/B000056NQL/qid=1041027787/sr=1-2/ref=sr_1_2_etk-tools/104-3473250-5231917
This is exactly what I need, but it doesn't fit my miter gauge.
Janet
I don't know. Maybe you can alter it or the miter gage to make it work.
A Merry Christmas to you!
I'm going to go on a tangent and say get rid of your miter gauge and replace it with a simple table saw sled that will do everything the miter gauge will do and more,with greater accuracy.
It is simply a 2' x 4'x 1/2" mdf base with 1/4" x 3/8"x 2' runners of hardwood or UMW that run in the machined grooves on your table saw.
A 1" x 4" x 4' rail on the front and back that are SQUARE to your fence, complete this sled...easy to clamp to, nail to,whatever...I built one several years ago and haven't used my miter gauge in years, except for today when I used it to trim 5/8" dowel to 9/16".
Always square,a greater margin of safety,very adaptable for set-ups and small pieces and,except for being heavier than a miter saw gauge, there is no down side to a table saw sled.
cheers,
silver
Silver, how do you deal with pieces that need to be cut at an angle?
Janet
I'm a low tech kind of guy...cut the angle with your miter gauge ar preferably with a chop saw.
If you're using the sled for multiple angle cuts, use the angled piece for a simple set-up using a 1x3 screwed to the sled base on the left side of blade at the correct angle. You can even corral your pieces for a higher safety margin by adding another piece as a keeper and your stock to be cut would just slip between them, if you're getting my drift.
It turns the table saw into a poorman's version of a sliding table and in my opinion is vastly safer and more accurate than a miter gauge.
cheers,
silver
Edited 12/30/2002 6:41:32 PM ET by silver
I agree completely with silver, except you want the rear fence of the sled to be perpendicular to the saw blade. Ignore the normal fence.
To test squareness, take two pieces of wide hardwood that is jointed (say, 8 inches wide). Cut both with the wood on the left side of the blade. The fence is fastened down but still moveable (not glued). place one piece, jointed side down, on your table. Place the other side, jointed side down, and swiveled 180 degrees, so that the cut sides abut each other. If you cannot see light through the cut you have a completely accurate fence on the sled. If there is light at the bottom or the top, you're off, and the error is half what you see (the error is doubled by doing what I suggest). Tweak the fence until there is no light. You've now got a perfectly accurate cutoff sled, and it does wonders.
One caution here. Never, never, use the sled with your hand where the sawblade will come through the back fence. To be perfectly safe, place a shopmade guard on the back side of the sled which covers the blade as it comes through the back side.
And you want the front and read fences tall enough so the blade doesn't cut complete through them, or else your sled will be in two pieces and will be useless.
John
