I am making a childs cradle which has four sides that are angled out at 75 degrees. I need to glue them together but my question is how to clamp them together while they are drying? Do i make a jig that is 75 degrees on one side and 90 degrees on the other so normal clamps will hold them while they dry or does someone have another better idea?
Harold Barre
You can cut some angled blocks and tape them to your clamp faces, the angle will be the 90 degree complimentary angle to 75 degrees, 15 degrees.
Clamp
Have you considered band clamps ?
SA
To stop any clamp blocks from slipping we will double tape some sandpaper onto the block , a quick fix is just to turn some rough paper onto itself and use that as a non slip tool .
Noithat
acacacaca
