I’ve got a #2 clamp that has a bent screw.
Wondering if anyone has ever replaced this on one of theirs and where to find the parts…
Maybe it isn’t worth trying to replace this piece but I hate to toss an otherwise useful tool…
I've never done it and don't even have any hand screws (short list item). But it should be pretty easy to replace. Worst case get a piece of the right size all thread rod and epoxy an wooden handle on. Might not be worth the time for a pro but I'd probably do it as I woodwork for fun.
If you can't find the right kind of all thread locally, Mcmaster Carr should have something that will fit.
Uh, the threaded shafts on Handscrews are not all thread in the traditional sense. Half of the length is right hand thread, and the other half is left hand tread. All thread will not be a solution. I don't know a source for such things, but they are probably available somewhere.
CTSailor is right. Lee Valley sells kits. I'm not sure how the sizes match up. https://www.leevalley.com/en-ca/shop/tools/hand-tools/clamps/69826-dubuque-handscrew-kits
That makes sense. If it were all right hand it would never tighten....
I would think you could straighten the one that's bent. Unless you ran it over with a truck, it should straighten ok.
Yep, it basically was run over ;(
I'll check out the Lee Valley parts.
For 11 bucks I'll give it a whirl.
