Received my General International 50-185 and have the top up-ended. There is some gunk around the edge of the top, presumably on the top as well, and in the worm gears. Maybe some other spots I’ve missed too.
What is the general rule about removing this stuff or keeping it? Any other gotcha’s I should know about this particular saw?
At the moment the only assembly I’ve done is the base. I’m guessing that if I have to remove the gunk it will be easier with the machine upside down.
BBR
I remove what is there as it is sometimes heavier than needed or more as a rust protectant. I would use never seize or a similiar dry moly lubricant on the worm gears.
When I unboxed and cleaned up my new Unisaw last fall, I used a product called "Grez-Off" from an auto parts store. A box of those disposable paper rags is real handy for removing that grease.
Take off the majority of it with rags and then clean it with kerosene. Use Topcote or wax to protect the top afterwards, and lithium grease or graphite on all the gears. Don't cut any wood until you've cleaned the gears well or the shipping protectorant and the saw dust are going to become one huge pain to clean after.
Brent
Edited 9/17/2005 11:21 pm ET by BrentS
Most new machinery is coated with grease when shipped. This is good for shipping but bad for use - sawdust adheres to grease. Remove the grease with alcohol or acetone and apply a nice wax instead.
Propmonkey
I don't want to be otherwise here-but acetone or alcohol are not good-will attack the paint work, to say nothing of the acetone fumes and headache to come.
It would be better to use parraffin (kerosene in the U.S I think) in between sipping delicately at your Jack Daniels.
Parraffin, with lots of paper towels, followed by clean rags , followed by Southern Comfort.No fumes, no headache and a good anti-rust.
Philip Marcou
Hi Philip,
Sounds like you and I are using variants of the same formula: Last tablesaw I assembled involved naphtha to remove the rust protectant, paste wax with a high carnauba content to protect the clean-but-vulnerable cast iron surfaces, and 18-year-old single-malt scotch to relax and celebrate the completed project!
Sawdust in your shoes,-Jazzdogg-
scotch tastes like the sawdust from my shoes after a hot day working! ;)
Sorry, couldn't resist.
Philip.. Now THAT is good thinking!
That "stuff" is cosmoline, to protect the saw while shipping. I use a wide spatula to scrape off the bulk of it on big wide surfaces, kerosene to get off the rest. Most manufacturers say do not use strong solvents such as lacquer thinner. Once you get it all off, give the table a nice coat of furniture wax (Johnson's, Minwax, or Butcher's wax), update periodically -- how often depends on the humidity at your place.
