Hubby is making a knife handle out of deer antler, and needed (?) to use my grinding wheel to smooth it after it was cut, 80-grit wheel I think. Now there’s melted deer antler coating the wheel. What’s the best way to get it off?
Another proud member of the “I Rocked With ToolDoc Club” …. :>)
GURL,
Buy a diamond wheel dresser at a machinist's
supply (Cheap) Attach a collar that will fit
the shaft (!/2" is pretty standard) The collar
can be bought at the same store (Very cheap)
It has an allen set screw that locks
it onto the shaft. Adjust the diamond point
to ride left to right and back to the left
while the collar rides along the grinder's
tool rest
Dress a tiny bit at first.
That will clean off most of the junk
Shut the wheel down, Observe the wheel
It will show new clean surfaces but some part
of the edge still needs a tad more.
Readjust the dresser and take a finishing cut.
This not only cleans the wheel, but
it wears away any unevenness and the result
is a perfectly round and centered wheel
Ed from Ct
Edited 1/16/2005 6:16 pm ET by steinmetz
Thanks, Ed. I've seen those in catalogs. I'll see if the local Jet/etc. retailer has them.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Get a star wheel dressing tool, it is a cast iron handle with a group of pointed steel discs on its working end. Place the end of the tool on your grinder's tool rest and pass disced end back and forth across the face of the spinning grinding wheel, while pressing the dressing tool lightly against the wheel. The star discs will spin noisily and make some dust as they scrub away the face of the wheel, in a few seconds the wheel's face will be clean. Anytime you do anything at a grinder you should have on safety glasses or, even better, a face shield.
I real hardware store should have a star wheel dressing tool, it shouldn't be too expensive, probably around $10.00 or so I'd guess. While you are there, pick up a set of replacement star wheels if they have them, they wear down eventually. Use the dressing tool regularly to clean up the face of the wheel, the wheel will cut both faster and cooler with a fresh surface.
Hope this helps, John W.
Thanks, John, for pitching in here. Seems like the star-wheel would be good for getting the gunk off. Does it do the final "dressing" of the wheel as well as Ed's diamond dresser? [BTW, looks like our Ace doesn't qualify as a "real" hardware store. They only have the bar-shaped dresser that looks like a rectangular grinding wheel, so to speak).forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
I use the diamond dresser when I am shaping the wheel to grind shaper knives.For normal use the square block should do a satisfactory job
Work safely¬¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬¬¬Thank you,Mr.Croney,where ever you may be.
Work safely ¬¬¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬¬¬
The dresser with a set of star wheels does work really slick. Occasionally, I will shape something made from aluminum on the grinder, which leaves chunks of alum. imbedded in the wheel's surface. The dresser cleans it up in a hurry, so you'll not have a problem cleaning off the residue from hubby's antler project. Years ago, I got a handful of what were called "dressing sticks" from an industrial supply place -- which I think is what you are describing. Anyway, mine are rectangular sticks -- maybe 6" long, and something like 1/2" X 1/2". These can be used to further smooth the wheel, if you think it necessary, after using the dresser.
If you use the starwheel type, once the debris is gone, move the dresser across the surface of the stone to even it out using the edge of the tool rest as a guide so it will be square. There will definitley be some dust and you don't want to inhale it or get it in your eyes.
