This is NOT a tip for Fine Woodworking type finishing, but it came in handy for me so I will pass it on:
I have been doing some exterior residential trim painting the last two weeks and ended up with two expensive brushes clogged with gunked on latex paint. My usual method of cleaning by washing in the sink with warm water and dish detergent didn’t help much. What did work better than I expected was a cleaning product called Simple Green. One part SG to about four parts warm water in a coffeee can, soak the brush overnight, rinse in warm water. They came out completely free of the gunk. I had used this stuff for cleaning saw blades but had no idea it would work so well on brushes. For whatever its worth. Gary
Great, I just happen to have some SG in the shop. Never thought of it for the brushes. (For that matter, never thought of it for the saw blades - usually cook with baking soda.)
Thanks!
Thanks for the tip. I was just getting ready to trash an expensive trim brush my SO failed to properly clean because of lack of experience.
I'll give it a try.
dm
So you discovered SG too, huh! LOL
My buddy is a professional painter, and he turned me on to that stuff about 6 years ago, and wow, it really works great. Over night and they're like brand new again.
Jeff,
I got two stories about Simple Green;
First story is I had a teflon coated router bit that needed cleaning. I soaked the bit in straight SG, it cleaned the bit great but completely removed the teflon coating from the bit. Woops
Second, wanted to clean my WW II tablesaw blade. Needed something for the blade to soak in, how about the LOML aluminum cake sheet pan. Really bad idea, the SG completely removed the mill finish from the aluminum and eched the aluminum.. Needless to say it got me in the dog house with the boss lady..
Best of luck
Oh, Yes!!
Anything that will remove burnt on axle grease from a hotrod will definately ruin cooking utensils. LOL
There's more to it than Simple Green, IMO. First, get a quality brush. Next, regardless of what mild detergent you use.. invest in a $3-$4 brush Comb. You can run water through a brush forever and it will eventually appear clear. Run the brush comb through it at that point and you may discover there is still gunk deep inside you can't see. The comb goes deep and speeds the whole process.
I paint a lot and have still got brushes in all sizes that are 10-15 years old and still going strong. And occasianal trimming and shaping of stray brissles with a pair of sizzors is required, especially on good trim brushes.
Having two brushes also is an aid when doing big jobs. At some point you clean the first and set it up to dry. Back to work with the other and vise versa. In the long run, it saves time on clean up and the results of the finish are enhanced as the cleaner the brush, the less the drag and more efficient the spread.
Have a good day...
grinder47
