I’ve borrowed a belt sander and need to get as much use as possible out of the belts I’ve got. In the absence of a proper belt cleaner block, how can I clean some of the build up off?
Thanks in advance.
Roger
Thanks in advance.
Roger
I assume you are sanding pine with pitch. Old crepe sold shoes are pretty much the same as a belt cleaner stick. I've also used some Clean and Green. Best for cloth type belts. Spray it on, let it soak and rinse it off.
Crepe blocks are not really expensive and they last a long time. Just in case you don't have any old crepe soled shoes around, why not just get one. Sounds like you got a grat price on the sander and you could renovate all those old belts. The crepe blosks also work with good old hand sanding so it won't be wasted.
keith
Roger,
If you don't have a belt cleaner & the build up is not a lot of pitch, try a bit of PVC water/sewer/electrical pipe. For pitch see above. If time is not of the essence you could also try soaking the belts in water but the join may come apart (so try a pretty far gone one first).
Don
