I’m in the process of finishing a bookcase with shellac. I like the look of the shellac rubbed out with 0000 steel wool to create a satin finish. When I rub out the last coat though, I’m left with little shellac dust and steel wool fibers over the surface and in some of the nooks.
What is the best way to clean up the dust and to clean the final coat while leaving the satin look?
What is the long term cleaning/polishing/waxing solution should I use to keep the finish looking good?
thanks,
Joe
If you can get it outside blow it out good with compressed air. As far as cleaning/polishing goes I'm a fan of Pledge on a soft cloth but there are probably others more qualified to advise you on that.
Wipe it off with a damp paper towel.
Makes any leftover/missed steel wool rust.
Since the house is on fire let us warm ourselves. ~Italian Proverb
I have good luck using Liberon 0000 steel wool lubricated with Howard Feed & Wax.
Be cautious around edges where finishes tend to be thinnest, and avoid applying point pressure, lest you inadvertantly cut through the shellac with your steel wool.
Wipe up residual oil with clean, lint-free, cotton rags (old, well-washed, t-shirts or diapers work well).
Works to performs a basic rubout to a satin sheen as well as for ongoing maintenance.
-Jazzdogg-
Wipe it off with a cloth moistened with mineral spirits--not water, although it probably wouldn't hurt much, but you don't have to do it.
I like to clean with microfiber cloths. Get a pack from your local big box, they work great and can be washed many times. They are also excellent "tack cloths."
Here are a few things you can do. First, use gray scotchbrite pads instead of 4/0 steel wool. It will work as well without leaving little steel shards all around to later rust in your finish.
You can also use the scotchbrite pad dampen with mineral spirits to clean up what you have. Or, use a rag dampened with mineral spirits. Vacuum it up first.
You can wax the surface but once you start, it's a lifetime job. Wax gets gummy and collects dust over time which requires cleaning and rewaxing.
I stongly recommend not to use any supermarket "polishes" like Pledge. They are mostly mineral and have not long term effect except to collect dust. Many--like Pledge--contain silicone which can make any future finishing efforts a problem
