I was wondering if anybody knew the best way to clean a table saw top. I managed to get some coffee stains on it. I tried lacquer thinner and steel wool but it did not seem to work. Any suggestions would be grealy appreciated.
Pour coffee over the rest of it to even up the patina.
PlaneWood
Sport,
I recently bought two spray containers at Woodcraft..one for rust removal and one for cleaning blades. I used both on the table top and waxed after that...did a nice job of removing stains...none were coffee however.
There are two things I'm really adamant about with my shop - don't stand in line with the table saw blade, and don't even think about setting any kind of drink on the cast iron!
After my previous rather flippant remark, I will add that there's little u can do, short of electrolysis, to remove stains from cast iron due to its porous nature. Keeping a good coat of wax on the top can help prevent stains and rust.
My saw top has had a plethora of stuff spilled on it - coffee, glue, paint, blood, you name it. Over the years it has developed a nice dark patina with a character of it's own.
'After my previous rather flippant remark..."
Mike,
Now that I think of it, why not? May be worth trying, especially if the mark really stands out, can't be removed, and really bugs the guy.
BTW, good to have you back!
Try using plain old white vinegar.
First clean the entire top with the stuff, then after you have cleaned the mess up, pour a little on the stain and let it sit a while (Don't let it sit so long it starts to evaporate or dry!). Wipe the vinegar off and repeat until you feel you can no longer improve your results.
Wax your table afterwards.
Of course I am no chemist, machinist, or cast iron expert so I am just conjecturing on this (I do use vinegar to clean all my cast iron tools thought) and its effectiveness. Vinegar is one of the few things I have found that will actually clean concrete too. It will remove blood stains, grease stains, etc...
Lazarus
"Wisdom is the toughest of teachers! She gives the test first and the lesson after."
800 grit wet/dry and some 3-in-1.
