All,
I just picked up a Disston D-8 Rip saw at the flea market. It’s in pretty good shape but I’d like to work a bit on the black spots without removing the emblem. Any suggestions for cleaning up?
All,
Use a rigid sanding block, nothing softer than cork, and 400 grit silicon carbide sand paper. Avoid coarser papers and lubricate with any light oil, I like WD-40 for this. Keep an eye on the etched logo as you go. Polishing with finer papers is also a good idea--you can line up the real edge of the stock you're cutting and its reflected image to "eyeball" a very square cut. When they appear as a straight continuous line you are square.
Larry,
Thanks, I'll remove the handle and do the sanding on the table saw to keep everything flat....it appears to have a light coating of oil on it right now so some one took care of it..
Like Larry suggest a good sanding block and some automotive sand paper and it should clean up nice. I use 3 layers of 3/4" MDF glued together to have a very solid and flat surface.
Check out the following website it has some good info on Disston saws.
http://www.disstonianinstitute.com/
Scott C. Frankland
Scott,
Yes, I spent some quality time at that web sight when I got home from the flea market. I suspect this saw is a 'Regular D-8 Rip (no thumb hole)from the 50's with a red beech handle....however, the teeth count is more than 5 1/2 per inch. I need to recount teeth over a greater span than one inch to make sure..it may be 7 count. Whatever it's fun to have one...
