Hey guys,
I’ve got a table top that we have finished with a latex crackle finish. I’ve applied the manufactures clear coat spray but it doesn’t build up any decent thickness. I’ve covered it with several coats but it still looks as if it might scratch, peel, and wear way too easily.
Any suggestions for a thicker clear coat that can be used over a latex paint finish? Spray or bruch on, I can go with either one.
Thanks.
Mike,
I have used both spray lacquer and marine spar varnish over cracked latex finishes. The varnish can be applied with a rag and does take longer to dry. If I were doing it for someone else I would use lacquer, it is quicker, if I were doing it for myself I would choose the varnish.
Stephen
*Thanks Stephen.Mike
