Hello,
I am building some raised panel doors and was wondering what the clearance is for the panel. I have read 1/16 to 1/8 all around and I have also heard no clearance is necessary at the top and bottom.
Any help would be much appreciated.
Doug
Hello,
Doug
Doug,
There was an interesting discussion about exansion/contraction recently. As your aware, each wood has its own expansion coefficient, however, no one is really sure what environment the piece will be subject to over its life time. My take away from the discussion was to provide 1/4" expansion for every 1' of panel width...and maybe 1/16" for the length.
If you space the sides but don't space the top and bottom the same, the profile on the raised section will show differently around the frame. If you use spaceballs or short pieces of plastic tubing, it will give a clearance of about 1/4" all around. Both the spaceballs and tubing will compress if the panel expands and keep the panel centered. Makes it easy to make the panels 1/2" less than the available space in both width and height. This should be adequate extra space for solid wood panels up to 22" wide. This, of course, is if the lumber is milled assembled and finished close to 6-8% moisture content. It always helps to seal the end grain on panels before assembly, at the minimum.
I usually figure about 1/16" per foot of width for flatsawn lumber and tight on the ends of the panel. Of course that will depend on what time of year it is and the moisture content of the material
doug07, been fabricating doors for 20 years, 1/8inch is enough!!!!!
-Lou
1/16" top to bottom,you probably can get away with 0" clearance. The side clearance depends on the size of the panel, type of wood used and the climate. In general 3/16" total will work. I do not use space balls,never seen them .I pin the panels from the back with a small brad. The brad goes in the center of the top and bottom rail.I drill a 1/32 hole in the rails,then pin with a 3/8" brads.Make sure the panel is centered before pinning. The panel can expand on each side of the center rails and still be centered in the frame.
mike
