rcently when ripping on my table saw the material seems determined to rixe, even before it passes center of blade. It;s to the point that I have to hold it down. I don’t know whats causing this as the rotation of the blade shaould force the material down. at least initially.
Is the blade sharp? is it in the right way round? sorry but we need to know.
regards Teabag
It's possible that the blade is not as sharp as it is supposed to be. It's fairly new though and I haven't done that much cutting.. ??? I have changed it several times with a dado blade but I think it is in correctrly.. Theeth face forward and I believe that is the correct rotaion.. Forward and down.. What do you think...
yes, the blade sounds as if its in the right way round so if its riding up BEFORE...it gets to spindle centre I would go for dull blade. one of the other posts mentions if the guide toes in you would get upward lift BUT only after passing centre, before centre you would get pinch.
regards Teabag
The front of the blade pushes the stock down, but the back of the blade will lift the stock. The most likely cause of your problem is that the rip fence is toed in forcing the wood against the rear of the blade.
John W.
I'll chjech that... thanks
If the blade is in correctly, the teeth point towards you, the boards should not climb unless it is less than 10" long.
mike
thanks to all.. It was a dull blade,I put on a new one and it works fine.. I guess I coulsn't believe that the blade was dull even though I never checked it.. Thanks
bobbyboy , Sometimes stock that is bowed can bounce and rise as well as very thin stock . What material gave this problem or is it all the stock you run does this .
dusty
Are you sure it is a rip blade? Rip blades have aggressive hook angles and fewer teeth (fewer teeth = larger gullet) and should push down on the stock by their nature.
Freud America, Inc.
