My finance recently bought two solid maple doors for her basement. They were unfinished and having done refinishing projects in the past she felt this would be a relatively easy and pleasurable project. She began with sanding and staining. When it came to the final finish she applied coats or Minwax polyurethane. The first coat looked great however successive coats turned white and cloudy in areas. She sanded these areas and reapplied the finish with similar results. She has used a clean brush. She has used mineral spirits as a solvent to clean the brush or in a rag as a tack cloth. The work has been done in a garage with temps in the high fifties to the 70’s depending on the day. The humidity has been low. Any clues to her problem? This is driving her crazy.
What kind of stain did you use?
the stain was a Minwax Stain
Oil based for both then?
24 hours between coats?
I don't see how it could happen, unless there was water under there somewhere.
I use the same stuff -- the biggest problem I have with it is keeping dust off of it while it dries.
Water, moisture or humidity is what I had thought might be the problem. I'll inquire further. Thanks
Is the poly water based, or oil based?
the Polyurethane was an oil-based finish.
Is the thinner old or contaminated? Try cleaning the brush with new thinner - or using a new brush.
Contaminated solvent. That's an interesting idea. I'll check. Thanks.
I'm reaching with that one. Cleaning water based marerial out of a brush with paint thinner seemed like a better possibility. - lol
Was the poly already opened? How old is it (Minwax puts a Julian date on their products).
If the first poly coat was o.k., there must be a reaction between the successive coats. Was there any additives in the "tack cloth" rag?
Moisture somewhere seems the best answer.
Pete
Let me throw one more question into the hopper.
Is the finish she is using gloss or satin?
If what is being seen is sort of cloudy, gray areas, it sounds like a non-gloss finish that has not been thoroughly stirred. Non-gloss finishes should be stirred 100 strokes in one direction and then 100 strokes in the other keeping the stirrer in contact with the bottom of the can. Re-stir periodically during application.Howie.........
Edited 5/21/2009 3:30 pm ET by HowardAcheson
I vote for Howard's idea. Good sleuthing, if it is a satin finish. ;o)Gretchen
Yup, but if it were not mixed well, the flattening agent would still be at the bottom of the can.
...UNLESS! By the time the second coat was applied, they were at the bottom of the can.
Possible solution: Get a bigger can!
And the cloudy layers were put on late in the application--yes, wasn't stirred, as Howard said.Gretchen
Errrr... Grechen?
Please re-read my earlier post -- and imagine the theme song from Maxwell Smart playing in the background. ~;-)
>>> Yup, but if it were not mixed well, the flattening agent would still be at the bottom of the can.Not necessarily, but some would. If the flatteners are not evenly distributed throughout the liquid, as you dip your brush in you will end up with more flatteners in some areas of the mixture than in others.
However, if incomplete mixing is the problem the fix is easy. Buy a new can, stir it properly and apply a new coat. The gloss is determined by the last coat applied so it will end up with a uniform sheen."Gray" patches or streaks are in the top three issues that I deal with on the Minwax forums. It's an almost universal problem with new or inexperienced finishers when using non-gloss finishes.Howie.........
Hopefully the OP will post again to let us know if that was the fix.
I use satin poly once in a while, but I've never noticed any clouding. I mix the snot out of it tho... not 100 times in both directions (!), but I make sure the hazy stuff (flattening agents) is well incorporated.
Have a good weekend
