I bought some two cherries chisels. They seem to be coated. Should this coat be removed before putting them to water stones? What is used to remove this coating?
Rod
Rod
Soak the chisel (Not the wood handle) in lacquer thinner overnite.
A tight bottle works good with something around the top to prevent evaporation.
The coating will either dissolve or slough off by morning.
Don't try the stone route till you remove the coating, it will clog up your stones.
I put the chisels in acetone for about 2 hours and they were free of the coating. So thanks for the tip. Maybe a shorter time would have worked just as well. I never thought of using a card scraper. Now the backs need to be flatened. The first one shows that it wont take too much time to do. Thanks for all the replies.Rod
as Jeff said, remove the coating. If you don't it makes a mess on a DMT stone, too. DAMHIKT.
I agree with SARDog but my experience with two cherries (11 chisels, 4 carving tools) is that the lacquer comes off in about 2 minutes when dipped in lacquer thinner. I remove the lacquer from both the wood handle and the steel shank. I finish the wood handles with BLO and wax. The sticker on the handle is FOD (Foreign Object and Debris - i.e., trash, not saved). Good luck, Ed
I just use a card scraper to take off the coating it only takes a couple of seconds.
I like to call up my ex and just sort of casually drop the news that I just bought a corvette and now have a 22 year old girlfriend, while at the same time asking her if she's going to qualify for Earned Income Credit on her tax return this year. Then I just wrap the chisels and the phone receiver together up in a towel, wait a few minutes, unwrap them, and the coating is just blistered off with very little effort on my part.
Is it cold in here, or is it just you? <g>My goal is for my work to outlast me. Expect my joinery to get simpler as time goes by.
Wow, that's a great idea! But you have to be careful, if your ex is anything like mine, besides taking off the laquer, the handles would be carbonized and the tool steel would be annealed!
David
