I’ve had a Coleman 11 gallon (4 hp) compressor for a couple of years. It is the oil less model. I have used it very little and of course today I needed it. I plugged it in and it started making very loud noises, like the engine was going to blow up. So I unplugged it for a while and tried it again but the same thing happened. What do I do now? Any help would be appreciatted.
I think you already know the answer - haul it to the dump, then go to an automotive or industrial supply shop and buy a good cast iron unit that will serve you well and someday will be handed on to your grandchildren, whom it will also serve well.
I'll admit it I was in denial. Thinking it would be worth fixing was a pipe dream. You have brought me to my senses. Any recommendations?
I know they sell repair kits, I've hear the pistons on those unit are plastic. You'll basically be rebuiling the thing.
john
Hi John, I took the plastic shroud off the thing and there laid the piston broken in two pcs. I called Coleman today. This is a joke.
Hi joeyb
Goodluck.
I will agree oilless is not the way to go. I have a Campbel Huasefeild 220v, castiron, 6hp, single stage, 10.3 @90 and it's nice having around. They run around $425 and are worth it.
john
I would be happy to own a unit like that. We will see.
I would assume that Ingersoll-Rand and Campbell-Hausfeld still make quality units. I've noticed that my local Sam's Club has had a 7 hp. Porter-Cable unit for a rather tempting price. (Why are all these names hyphenated???)
Best bet, again, is to check with an auto body shop or an auto parts and equipment dealer - a real one, not those chains.
You might watch auctions, estate sales, etc. for a used one. I once had a small unit that came out of a dentist's office. Didn't produce a great volume of air, but you couldn't hear it running from 3 feet away. Now that was a well built machine.
Hey Jeff thanks for the reply. I am talking to Coleman about there poor workmanship. Depending on there decision I will move on to a real compressor.
Joey,
I've had good performance from my oil-lubricated Hitachi. It's sufficient for nailers, but wouldn't work for air hogs like sprayers. I got a good deal by purchasing a remanufactured unit -- bought a new brad nailer with the money I saved.
Good luck,
Paul
I have seen the hitachi units and they look to be of good quality. There is a company here in Minn. that makes compressors. (c-aire) and they are heavy duty. I will not "underbuy" again. Thanks Paul
