May 2, 2007
Good morning to all,
I have a language problem, and need your help. My native language is Dutch, and I can’t find the exact meaning of the word “commercial grade Phosphoric Acid”. I encountered it in Taunton’s finishing booklet.
I was reading this booklet on finishing. On page 184 a method for retaining the beautiful sandy color of teak (Tectona Grandis) is explained. I’m supposed to mix 90 % alcohol with 10 % commercial grade phosphoric acid, and treat the teak twice with it.
What does that mean, commercial grade Phosphoric acid? Does it refer the purity of the solution? A very pure grade? What is the concentration of it (or do you say dilution? or strength?) is meant by it? Is it about 50%, or maybe 15%. I have no idea.
I will have a look tomorrow in the finishing thread. By the time one of you sees my question, I will be sleeping.
Geert van der Donk
The Netherlands
10% phosphoric acid is 10% phosphorous to 90% vehicle. As 10% saline solution is 10% salt to 90% water.
Commercial denotes a high concentration, and for safety reasons is usually only available business-to-business, or lab supplier to lab. Not sure of the rules in your country...
many ways to achieve an aged teak look, some being safer than others.
Expert since 10 am.
Don't get hung up on the grade. I seem to recall industrial, commercial, and food grade. H3PO4 is one of the milder acids I've worked with, but still very dangerous and should be handled as such. Acids are often more corrosive and do more damage to the eyes and skin in weaker dilutions. Protect your eyes and skin. Wear a face shield over full wrap eye protection. Regular safety glasses leave too much room for a splash to get to the eyes.
Check with your local chemical supply. I know a 15% Solution is available here. I believe the dilutions are by weight. So rather than offer calculations to make a dilution, ask the supplier for a 10 % solution. If they can't create one for you, he/she should be able to tell you how much water to add to arrive at the 10% solution. If not, post back to this thread and one of us will give you the volume of distilled water to add.
Edited 5/2/2007 8:34 am ET by Cincinnati
" If they can't create one for you, he/she should be able to tell you how much water to add to arrive at the 10% solution."
Not sure if it applies here, because I don't know what the user will be dealing with exactly, but I was taught NEVER to add water to acid. To dilute, always add the acid to the water. Doing it backwards can cause the water to boil explosively, splashing acid around.
Mike HennessyPittsburgh, PA
You are absolutely correct: Acid to water, SLOWLY, and pour down the side of the container if possible. I didn't think to go into that detail. Thanks Mike.
I'm not 100% sure, but I believe the term "commercial grade" refers to the purity. Chemical supply houses sell varying degrees of purity depending on the intended use, and of course the more impurities the lower the cost.
The highest purity is called CP (chemically pure), the next lower grade is called Analytical, and lower than that is called Commercial. Again, I'm not completely sure about this info but I believe it to be so. For finishing purposes the commercial grade is more than good enough.
David Ring
Phosphoric acid is the main ingredients in Marine Teak Cleaners such as this
http://www.marinetex.com/index.htm
I'm sure you can find a similar product in your country.
Thank you all!
I will take Dyeman's advise, because I'm almost treated as a criminal if I ask for concentrated Phosphoric acid and Alcohol. They look at me as if I where a bomb builder. If the main component of the marine teak cleaner is Phosphoric acid, I'm done thinking.
Thanks again,
Geert van der Donk
