Complete removal of boiled linseed oil ‘staining’
Thanks in advance for any help/advice that someone can offer.
I have a maple neck on a guitar that I recently acquired from someone, and I won’t call him an idiot, but trying to reverse something he has done.
This guy used boiled linseed oil on the neck, he said about 5-6 years ago the first time, and about a year ago as well. The result has diminished the appearance greatly, and also some staining that while a little hard to describe, appears slike flaming in certain areas. Others were completely darkened, taking away any possibility of seeing the grain in the wood, etc.
So, I would like to remove all of the boiled linseed oil ‘staining’ and any other effects on the wood from its’ application(s). I used some naptha and rubbing, and I believe that it has lightened, but of course, it hasn’t resolved the problem.
I guess my first question is if something like turpentine, or another solvent would remove the BLO. Also, if something like that would not, I am capable of sanding down the neck and refretting this guitar, but would like to avoid that if possible as the neck is in good shape…but, I would gladly do this if I knew it could help remove the staining completly. I wish this guy hadn’t done this at all because the guitar is 20+ years old, and the mere natural aging of the maple color would look fantastic at this point, but that’s not the situation.
Thank you all again, and I hoe that a solution may actually exist.
You may want to contact Dan Erlewine at Stewart MacDonald (www.stewmac.com), he's a guru of old guitar finishes.
I don't think there's a chemical that will remove the BLO without causing problems with the finish in adjoining areas that you probably don't want to affect. I'd think you could lighten it by continuing with naphtha and steel wool. After that, a seal coat of shellac to seal it off and top coat of lacquer might be a compromise. I don't think you'll completely remove it without removing some wood. On the plus side, I don't think BLO penetrates too far into maple. I'm not sure you'd have to refret just because you refinished the neck.
