Hi, I would like to ask for advise on a compound miter saw. The purpose is home use for crown and baseboard. As I do my amature analysis, I figure I only need single bevel but do need 12″ and have narrowed the choice to between Dewalt 705s and Craftsman Professional. Both cost $300. Am I on the right track and how do the brands compare? When I do a side by side physical comparison, it seems like the Craftsman is better made. Thanks for the help. Fred
Buy the DeWalt. That's what I've got.
I cut crown "nested" in the old fashioned upside down and backwards way.
Really, no need for the crown detents for bevel and miter.
I went through the same decision las fall. I ended up buy teh Delta 36-255L 12" compound with the laser. I didn't buy it because of the laser, some like it some don't. I bought it due to it's reviews which are generally great, and because of the price. I bought mine for ~250 through Amazon. Currently they are advertised for $319, with free shipping and an automatic $25 rebate. I love the saw. I've had no problems and it is a tank (Maybe a good thing, maybe bad)
I can't comment on the Craftsman as I have never seen or used it. I recently bought the DeWalt and am very pleased with it. I was particularly impressed with the quality of the cut with the blade it came with. I also got the Dewalt stand and some accesories. The length stop is awkward and sloppy. I made one myself that is much better. The other accesories are fine. I got the stops to do crown mouldings because I am old and stupid and usually get mixed up doing things upside dowm or backward. The stops make it easy and they are not expensive.
Keith
Hi Keith. Couldn't help but chuckle at your description of getting things backwards, etc., doing mitering with a miter saw. Me too! I have a devil of a time doing things reverse, etc. So, on my last job doing crown molding, I cut my two corner pieces and used them as templates. I wrote on them which was ceiling/wall side, what corner met the other corner and on the back, which indent/miter degree. It really helped me to have these pieces as visual references. I could lay them on the miter bed to see if I had the bevel going the right way along with miter. I saved them for the next job!
For the record, I have a Makita 10 inch dual bevel compound slide miter saw. I LOVE it. Got it from Tyler Tools in the reconditioned tools section. They shipped it for free. Came out of the box like new.
Any comments on negative rake teeth,I have found them much better than positive on drop saws!
I guess I am not sure what you meant. Can you explain more? Thanks
Will try,the teeth on some sawblades point backwards,called negative rake.
I noticed this some time ago on drop saw,so bought one for my 10inch Makita drop saw which had the teeth pointing forward,like the ones you would see on a table saw,found it cut much easier,so have use ever since.
Huh! Well, learn something new everyday! Hmm...will keep that in mind. So far, I am very pleased with the way the current blade is working. Cuts are smooth as a baby's backside. Thanks for the tip. Take care.
Are you sure you don't have the blade in backwards? :-)
Can I assume you haven't heard of negative rake teeth?
The :-) was meant to imply that I was joking...Actually I have heard of such a thing.And years ago when I sided my house (vinyl) we installed the saw blade backwards in my circular saw ... a cheap alternative to purchasing a neg rake blade...Mark
Sorry Mark,miserable gits we limey's:-)
Some while back I was comparing a 12" DeWalt CMS with a 12" Craftsman Professional CMS. Each was priced at the retail store at about $299. I would not have taken the Craftsman for the same price as the DeWalt.
However, I came across the Craftsman at the local Sears service center. It had a bashed in box and was price-reduced by a cool hundred bucks. The DeWalt became a non-contender.
I have no regrets. The C'man Pro saw is a very good unit and has laid out a generously good share of crown and baseboard and .... <so and a so forth>. I'd recommend it -- even at the same price as the WeDalt.
(Typo is lediberate) :-)
-- Steve
Enjoy life & do well by it;
http://www.ApacheTrail.com/ww/
Fred,
I've got the DeWalt 706 and have been completely satisfied with it. It would be a great choice for your application. All of these saws seem to come with a thin kerf blade. I'd replace it with a full kerf 80 tooth blade to cut crown. The thin kerf blade will deflect a little, especially when cutting bevels.
As someone else mentioned, when cutting crown molding do it the simple way: upside down and registered against the table and fence. That way, you have only one angle to cut.
Bill Arnold - Custom Woodcrafting
Click Here if you're interested in a good,inexpensive website host.
I would buy the dewalt again i own many saws and it is a great one but after the factory blade is sharpend a couple of times it may as well be an orniment the saw is used for crown and cutting newl posts of larger size
Punctuation is a wonderful thing!
Bill Arnold - Custom Woodcrafting Click Here if you're interested in a good,inexpensive website host.
Whatever unit you choose, I recommend a 60 tooth blade. The cut looks like glass when you are done...
Mark
I work for a large remodeling company and mostly see dewalts out on the job sites. It's true get your self a good quailty 60-80 tooth blade. I personaly have a mikita 10" slide miter saw and what I like about it is it will cut a true 12" wide board.
