i am trying to build some rectangular planters with beveled sides. i have a table to give me the miters & bevels, but when it goes past 45 degrees i am at a loss as to how to get that angle as table saws dont go past that. I know i should be able to figure this out , but I must be suffering from senior brain lock. HELP
On a chop saw, you just end up clamping a block to the bed to hold things at 90 and you rotate the work - think of cutting the 22 for a flag box (actually 67.5) - so on a tablesaw to rotate the work, you build an auxillary fence to hold the stock steady while standing on edge. Featherboards help keep the bottom from kicking out, and a 0 clearance insert is a really good idea to keep thin edges from heading south and ruining your day.
"If you pick up a starving dog and make him prosperous, he will not bite you. This is the principal difference between a dog and a man." - Mark Twain
Thanks RW . while waiting, my brain finally kicked into gear, & you reinforced my thoughts. I will cut the bevel first @90degrees , clamp it to a vertical sled< back off from 45 degrees to make the desired cut. Thanks again
pin
hmmmmmmmm.... the table I use, the blade angle decreaces as the angle of the work increaces. A 5 degree box, the miters are cut 44.75 and the miter gauge is at 5 (or 85 depending on how you look at it. A 20 degree box, the blade angle is 41.75 and the miter gaure is at 19.25 (or again 71.25). Where are you getting your numbers? I've attached a Word file with the table I use. Good luck!
Norse
When cutting Interior Crown Molding & have a acute angle I Use a 5"x5"x6" block Which Has a 45 deg. angle cut on the end place it against the fence subtract 45 from the angle I need & set the miter at that angle I use a angle finder to get the original angle I hope this might help
Hi pin, check this site out. You can download free trialware for shop math .
http://www.woodworkinginfo.com/
Bruce
