Hello everyone,
I’m planning on exchanging my 30-year-old air compressor (which shakes the shop foundations when running) with one from California Air Tools. I was hoping someone on the forum either is familiar with them or direct experience with these tools and be willing to give me your opinion and or advice. Thank you for your time.
t.j.
I have one and I love it. It gets light use I've never had a problem with it. The sound is quite minimal and you can have a conversation while it is running
The only downside is that I find the location of the on/off switch to be in a hard to get to place.
Ahhh, good to know. Thank you for your prompt reply. I've been looking at them for a while and the low DB's are very appealing. Also attracted to the auto drain feature. Appears to be a good upgrade for mine that gets moderate use. Thank you again.
I've got one too, albeit one of the smaller ones used just for airbrushing (it'd run a pin/brad nailer too, if I had one). Perfectly happy with it, well-made.
I have the smallest one they make and am very happy with the noise level. Dont forget to install the muffler. I dont use it that often so I cant speak to longevity.
I have the 10 gal vertical tank model. I'm very pleased with the noise level. As said, you can stand next to it and hold a conversation. Mine only gets occasional use, but puts out enough air ro run pin and brad nailers and a mall LPLV spray gun. Only complaint is the location of the tank drain valve on the bottom hard to reach. I re-piped it to a better location. And, the paint on the top of the tank soon peeled off.
Thank you, great info. I'm leaning in the same direction. Much appreciated.
t.j.
These compressors get good reviews but keep in mind your own use/needs.
While these compressors are definitely quiet, many of them do not have a very high CFM rating. While good for intermittent tools like air nailers and other low CFM tools, they may struggle to run grinders, sanders and other higher CFM hungry tools.
An excellent point. I will keep this in mind, Thank you for chiming in.
t.j.
I have their 1ho 4.6 gal (not the smallest, but next to it) and used the smallest at a shop I mentored in. I like it. A bit small for some of my needs, but I am considering one of the big ones
For the OP, I'll just add that the smaller the tank, the more the compressor will cycle, regardless of how quiet it is.
Often times it becomes a toss up between a small quiet compressor that cycles often, or a large loud compressor that cycles less often, your choice.
Once again, an excellent point and one I had considered. I didn't explain my intended use because I was looking for a general idea as to the quality of the equipment. I have worked with 100-gallon and 60-gallon 3 phase compressors in the past but fortunately I'm retired and now a hobbyist. My expected use is much like some of the others where it will be pin guns and light spraying with LVLP and touch-up guns. Your points are well taken and much appreciated in helping me make my decision. Thank you for your time and energy on my behalf.
Best to you,
t.j.
