A customer of mine has stained and varnished slab birch plywood 3/8 inset cabinet doors with exposed hinges. He wants to paint the doors white and use concealed hinges. Anybody know of a concealed hinge that will work with a 3/8 inset door and face frame construction?
Are the doors recessed 3/8" or are the doors 3/8" thick?
Lee
bldrbill ,
Myself and a few of my ww pals have tried over and over to use euro hinges on 3/8" lip doors without ever finding a hinge combination that works , sorry but unless someone here has an answer I think you are out of luck on this one .
dusty
why the hell would someone make inset doors out 3/8 ply???? anyway the only way conceled hinges will work is if they are not the kind that have a cup, try woodwookers supply they have some you just screw on. good luck, those doors should be warping shortly
Those screw-on hinges from Woodworkers Supply are not good. I used them for a medicine cabinet and had a heck of a time getting them installed and adjusted (they're cheap, and you get what you pay for). After less than 6 months my client called to say one of the hinges is failing.
I shoulda used a piano hinge in the first place...
No,you should have used Grass,Blum etc,the top end jobbies.
Blum says that their 170 degree cup hinge can do this. http://www.wwhardware.com/media/products/apcharts/blum170special.pdf
Okay, their illustrations are for a Euro-style cabinet, but you can add blocking behind your face frame to provide the mounting plane their mounting plate wants.
the blums work fine for this application. I made new doors for a vanity and used that blums 170* hinges, clip and spacer. I had to make blocks to even out the face frame
The doors are 3/4 thick with a lip all the way around so that they are inset 3/8 into the face frame. Thanks to all for your suggestions. I'll check out the Blum hinge.
Sorry I missed that they were 3/4",you will have no problem.
Go to supplier tell them what you want,they will give you appropriate hinge and base plate.
The holes to take the hinge is 12 mm deep on the ones I have seen,so would go right through the door.
I would try the Blum or Hafele agents to see if they do such a hinge.
Edited 3/19/2005 2:34 am ET by Cicero
You can get there using a Blum hinge designed for full overlay (about 5/8"), but instead of the usual baseplate you substitute a plate that is about 1/4" thicker. They make a variety of baseplate heights which come in handy for such things. If you cannot get hold of a higher baseplate just make a spacer out of wood. This will work with several of the opening angles, 110 - 170 degrees.
DR
ring ,
The problem will not be solved with a thicker base plate , it is the relation of the backside of the door to the cabinet face that needs address . Please if you can make this work not on paper but on a real piece of wood post the exact part numbers of the hinges and base plates . IMHO you may not understand the problem, I have been over and over this but never been able to come up with the correct combination . It would be real handy to solve this application but all the suppliers I have asked had no solution . All overlay door backs are more or less flush to the front of the face . On a 3/8" lip door the backside of the door is 3/8" back from the face . Then the pivot point changes the aspects drastically. At first it seems as though there is an easy fix , but I'm not so sure that is reality here on this one , sorry to disagree with your post , maybe you can teach this old dog a new trick .
dusty
I actually spent an entire day experimenting with different brands, mounting plates etc. As far as I know it can't be done.
another old dog
mike
Hey Old Dog ,
Even though the above post claims it can be done , I tried the 170 degree hinge and there was no way it would even come close to working . I do love a challenge but this application is a losing proposition . Thank you for concurring , I really don't like to sound negative or in any way discourage others from experimenting and learning . After all , IMO that is the benefit of this forum . And this old dog lives to learn new tricks .
talk to you more later
regards dusty old dog
Dusty,
I appreciated your scepticism about making it work. However, I am kind of an old dog myself, and I actually did a kitchen this way a few years back. So I knocked up a mock-up in the shop today and took photos so you can see for yourself.
The frame member is 3/4" thick, with a 3/8"x 3/8" rabbet.
Hardware: Blum INSERTA CLIP hinge with 170 deg. opening, FULL OVERLAY (Blum part # 71.6540)
Blum Cruxiform 2-part baseplate w/ 9mm spacing (Blum part #175H9190)
Shim made of 3mm masonite. In a real application I would make this spacer from something inconspicuous.
The hole for the hinge cup needs to be drilled 1 mm in from the edge of the rabbet. The mounting holes for the baseplate are 47 mm in from the edge.
What do you say?
DR
Thanks, I didn't think it could be done. This old dog just learned a new trick.
mike
ring ,
Very cool indeed . I guess for the original posters application where there is a face frame with the surface mounted 3/8 " lip hinges , you would increase the thickness of the spacer block until it is correct , figuring that there is a reveal behind the face , is that right ?
Thanks for taking the time and energy to share this great trick , my tail is wagging and my fleas are itching .
regards dusty
dusty,
Actually, if the cabinet is not too large I would probably make a false inner wall just to get a clean look. It would need to be blocked out to make up for whatever the face frame needs + another 3mm. Can even be made removable if necessary by hiding screws underneath the hinge baseplates. If the cabinet is really large and I needed to skimp on the extra wood, it could be done only on the front 4" or so, not the entire cabinet depth.
DR
This thread is very old, but if anyone comes across it and still needs it Salice makes a euro hinge for a 3/8" inset rabbeted door. They have one for both a face frame and frameless. Rockler currently sells them.
