I once saw one sold by Rockler, can’t seem to find one. I’ve rigged a quart plastic take out container which works ok but it’s not the best. Anyone know where I can buy one or how to make one? I like to keep my badger shellac brushes in solvent. Thanks
Use an empty peanut butter jar. Cut a hole in the lid. Put the brush handle through the hole (bristles down). Put a nail or dowel through the brush handle to support it with the bristle tips just above the bottom. Fill with solvent. Tighten the lid with the brush. Done.
And, it's fun to empty the jar.
That is what I use to have for my badger varnishing brushes, the chalenge was to find a peanut butter jar tall enough, found one but it was a party mix, took far less time to eat the content. To keep the lid air tight, I screwed a softwood block under the lid to which I screwed a couple hooks.
That's a LOT of peanut butter.
I have the Rockler, and it's fantastic. You could probably find a piece of Tupperware that's pretty much the same, and make a hole on top for the brush handle. There's a little foam gasket, just a round washer shape, that slides down over the handle to help seal in odors.
Modify a mason jar?
This is my solution. I use these only for shellac so I have never felt the need to fit a lid on it. I fill with alcohol before use, and top off as needed or just let it dry if not in use for a long time.
As a side, badger brushes are not badger hair, but bristle in this day and age.
I found a great alternative at "Tools for working wood", made from Ox hair
https://toolsforworkingwood.com/store/item/GT-SHEBRU.XX
I have those three TFF brushes for shellac (my main finish for the past 7 years). They are nice brushes. I bought all three sizes but really the 2" and 3" sizes aren't all that necessary. Even better than those are what Don Williams talks about in his blogs (Don's Barn) and some his writing. He recommends an artists 3/4" or 1" oval mop brush for shellac. I got one at Michael's (hobby/craft store) for all of $20ish. Just got one that felt fine to my fingers. After about 6 years of using other brushes and now about a year using the oval mop brush, I will stick with the oval mop brushes. I think they work much better than even the TFF brushes. The oval shape basically feathers the shellac making it much less likely to leave shellac tracks the shellac is thicker where the two brush strokes touch. I had spent years trying to get a better finish with shellac and these oval mop brushes did it. Don's written a fair bit about them.
For some reason it’s about impossible to find a real badger hair brush these days, I still have a couple Red-Tree brand real badger brushes that I keep in a safe :) . When I have a lot of spar varnish to apply, I use them and keep them suspended in a jar with diesel fuel in it. One spin and they are ready to go.
