Looking for suggestions on joinery for a contemporary TV stand similar to the attached picture (downloaded from http://www.jasonleesdesign.com). I’ve considered both sliding dovetail, as well as pinned and housed mortise & tenon. Need a solution that will eliminate rackiing, yet provide a clean aesthetic.
Overall dimensions will be in the neighborhood of 18″ high x 48″long x 14-16″ deep, and I am planning around 1″-1 1/4″ stock thickness.
Any feedback is appreciated…
Thanks!!
JM
Interesting design and a rather tough joinery problem.
JM,
Three possible solutions comes to mind:
(1) very wide (in proportion to the width of the vertical supports) and "thick" sliding dovetails;
(2) loose-tenon M&T, with several proportionally thick mortises in each vertical support and the mortises also being proportionally very deep (perhaps 4 to 6 inches) in each vertical support piece. I suspect -- but don't KNOW -- that the long tenon length will give you some significant leverage against racking; or
(3) a double dovetailed half-lap type of joint (see Sam Allen's "Wood Joiner's Handbook", p 145, in my copy)
Worth trying a prototype, perhaps, to see if it will meet your requirements.
Hope this is of some help, and good luck!
James
Great start...Thanks!!
It does pose an interesting joinery problem; glad I'm not the only one that thinks so...
For the lower joints, I'd run a loose tenon completely through the shelf. That is, it glues into the vertical pieces, and captures the shelf between the verticals. For the upper shelf, I'd consider screws and plugs, or Miller dowels; that's quick and secure. If you don't want any visible joinery in the top, I'd use a row of dowels in the top of each vertical. I make the holes for the row of dowels with a shelf-pin jig and a plunge router. The jig provides perfect spacing in the holes on both sides of the joint, and the plunge router ensures they're all at the same angle. One dowel would seem like not much holding power, but one dowel every inch across the whole depth of the shelf provides a lot of holding power.
Thanks everyone; I'm getting some really great ideas. Keep 'em coming!!!
I'd half-lap join the bottom shelf; the top shelf can be dadoed. I don't think you'll have an y problem with racking if you keep roughly the same proportions as the drawing.
Racking shouldn't be a problem since there appears to be a back. Even a back on only the lower section would pretty much eliminate racking, but it likely covers the entire back, though if there are any electronics in the lower sections there would need to be substantial ventilation.
Loose tenons would likely be easiest to make, and amply strong. If you customarily make tenons with a router, then they need not be loose, just stopped before coming through the front.
Though the esthetics call for the top to be the thinnest board, the span can be handled by making the cross piece that is hidden behind the doors and shelve a pretty beefy member that supports the top with a vertical divider between shelves and door unit.
