Hi, has anyone used the Contractor Saw Perfomance Package from Inline-Industries? It comes with a link belt and machined pulleys. I’m having a difficult time removing the factory arbor pulley from my Delta C.S. Any advice would be appreciated.
I have used just about everything offered by In-Line Industries.
The Performance Package is a nice improvement to my saw.
I had no problem removing the old pulleys, however if I had, I would clean out all of the saw dust, remove the set screw and heat the pulley with a tourch. This should cause it to expand enough to pry off. BE CAREFUL IT WILL BE HOT! I would have a Fire Extinguisher handy.
Another item that I like is the CONTRACTOR SAW PALS. It makes the Blade adjustment a snap.
http://www.in-lineindustries.com/
Hi Leo, my Delta C.S. uses what they call a Tru-Nut to hold the arbor pulley on. I'm not having any luck removing that nut, any advice? thanks RodM
Call Delta CS. There has to be a way to get that nut off.
HI Leo, I called In-line and they suggested I use a 3" by 12" piece of pine with a 5/8" hole in one end and mount that on the arbor in place of my blade than rotate the arbor so the piece of pine contacts the throat opening, that should hold the arbor shaft so I can get that nut off. thanks for your advice. RodM
