Convert planer dust hood to 6 inch diameter
P.S. I've also considered an HVAC "Register Box" like this one:
https://a.co/d/7pTmXE2
I would not change it at the hood, the manufacturer did the math on airflow to clear the chips. Add a foot of 4" pipe and then use a simple reducer to get to 6 inches. Just my $.02.
I have done much the same, just in reverse - 5" port to 4" ducting. It works remarkably well with a sufficiently powerful sucker.
Faced with the same problem, I chose to build a new dust shroud from plywood. With the 6 inch hose it now collects 99.9% of the dust.
Thanks for the suggestions. Gives me some options to consider.
