Will appreciate opinions from the joinery specialists….
I’m building a French cabinet, 40″ wide and 8′ tall. The bottom sides will be raised panels 16″ x 3′ tall and will provide part of the strength in the casework. I won’t be using face frames, so the base will be supported by these side panels, a top and bottom frame and a fixed center shelf.
So this is my question, will cope & stick be good enough, or should I rather go with traditional mortise and tenon for the raised side panels?
A cope and stick glue joint by itself is not strong enough to resist the racking forces of a cabinet that size. A mortise and tenon joint, or haunched tenon, would be preferred to add the strength necessary to keep your cabinet square over the long haul. I would even consider pinning the tenon. You can let it show from the outside with a contrasting wood for a design feature, or do it from the inside if you don't want it to show.
Hi Willie ,
First off I'm not positive by what you mean by a French cabinet , is it an Armoire ?
40" X 96" is a good sized box for a free standing piece , will there be a back? how about doors ? how thick are the frame members going to be .IMO that's rather tall for no face on a free standing unit regardless of the type of joinery.
What will keep the sides parallel the whole ht ?
The strength is derived from the frame regardless of the panel type in theory since the panel floats .
There will not be much argument as to which joint is stronger , but rather the application that it is being used .
good luck dusty
Thanks everyone, I will stick to pinned M&T and not take any short cuts.
Dusty, I have done one of these before and the side panels only with fixed shelves and top and bottom frames provides a pretty rigid structure. Makes things simple and building quick.
Attached a picture explains your questions, the back is only thin ply, while the front are doors.
The criteria I apply to my projects for these choices are pretty simple:
Steve
http://www.woodcentral.com/shots/shot52.shtml
Cope and stick joints can easily be strengthened with dowels or loose tenons. We do this all the time.
