I would like to build my wife a plate rack in the dining room and copy the finish on her cabinet. The finish is golden oak topped with poly, however it contains small pinhead size black blotches of many sizes. Questions, what is it, and how is it accomplished without smearing it over the stain?
It's probably paint. Manufacturers call this technique "distressing." It's accomplished by flicking your wrist while holding a wet paint brush from several feet away.
*Jed,Thanks, but what kind of paint is it, water or oil base, is it put on top of the stain or first?
*I used oil-based paint, but latex would probably work fine. This step should follow stain and precede your clear finish. I'd recommend you practice this technique first, using some white poster board to get a good reading on your results. The mistake a lot of people make (me included--the first time I tried it) is that they overdo it and splatter too much paint. You only need a little.
*Jed,What kind/size of brush did you use? How long in between stain, paint, and clear finish?
*Jed's method will work, but I get better results by dipping a toothbrush in the stain/paint, shaking off the excess, then, holding the bristles up, I rake the bristles with my thumb. The bristles fling the stain/paint on to the surface. Experiment over a piece of cardboard, first.
*Thanks all,I think with everyone's response I have a pretty good idea of how it is done. A toothbrush probably would give more control for applying the size I am looking for.
*Don's method will work great. If you have alot to do you can make a spraygun spit paint.
