I’m turning ash baseball bats for my grandchildren. (They are in the T-Ball league) They are too heavy and I need to reduce the weight. I thought about drilling a hole in the end and “corking” the bat. Does anyone know how a bat is “corked”?
Some info here: http://paws.kettering.edu/~drussell/bats-new/corkedbat.html
Jim
Jim, thanks that was just what I needed. I am surprised that this technique only reduces the weight of the bat by 1.5 oz.
ken,
what if one were to glue up several 4/4 boards to form one square turning blank and the center was left as hollow as one wished by way of a groove or plough? this could also be done by "staggering" the center boards in such a way as to create a hollow.
hope this makes sense.
eef
EEF, that is certainly a possibility. The trick is to make sure that the void is in the dead center of the bat.
ken,
yes, and this may be facilitated by running both edges of the center boards, in turn, against the fence and moving the fence and cutting until the desired groove width is reached.
eef
There is a good book (I forget the name--maybe The Physics of Baseball.) that discusses corking a bat. Apparently nefarious players do it so that the bat is a little lighter, and the player can swing it a bit quicker. However, the author, who has studied these things, says that choking up has the same effect, without disobeying the rules. Have the kids choke up on their bats and see if that gets the desired effect.
Is it possible that corked bats are illegal in T-Ball just as they are in MLB?
It would be bad for your grandkids to get a reputation that might keep them out of the big leagues later on.................
You've got a point. Unfortunately, since I can't reduce the weight of the bat to the required 13 oz. and as one other respondent suggested, wood bats may not be allowed anyway, the entire effort may have been for naught.
Edited 11/11/2009 11:11 am ET by Kenneth
Ken, if it was for the grandchildren, how could it ever be "for naught"?? It will be a very special reminder to them for years to come, probably even more special as the years pass . . . . and we do too.
Kenneth, it has been a long while since my son was in T-ball, but I am not sure they allow wooden bats. You might want to check with the Coach or see what rules apply. Just a thought.
Once my son got into high school, he was turning his own (very nice) bats . . . . but even then he was using metal in the games. . . . except during summers when they had a wood-bat league and you had to be a purist (ie, use wood).
Ineresting observation. I don't know if they permit wood bats but I'm going to check. I do know that even if I "cork" the bat, I will not be able to meet the weight requirement of 13 oz. However, since I have already turned the bats, I guess they can hang them on the wall for decoration.
