I have Just bought a Makita ls0714 sliding mitre saw to use mainly for skirting boards and flooring. Is it always necessary to clamp the workpiece to the saw as stated in the instructions or is it safe to hold the workpiece buy hand to the base and fence as often seen done by other saw users?
For square cuts you can generally make an accurate cut without clamping down the board. A clamp may still be called for, for safety reasons, if the wood is crooked, knotty, small, or isn't sitting solidly on the table.
For angled cuts, like a 45 degree miter, the stock may creep slightly when cutting, creating a slightly curved cut or one that isn't at the intended angle. The amount of creep being dependent on the size of the stock, the hardness of the wood, and the sharpness of the blade among other factors. So if you are making precise angled cuts, it sometimes pays to clamp down the stock.
Edited 5/1/2006 11:35 am ET by JohnWW
Thanks for the advice.
