Wondering what countersink bits builders are using on wood and brass??
What angle?
Who sells good bits?
Dan
What angle?
Dan
My personal favorite is the Weldon single flute(a diagonal hole) The Weldons are very chatter resistant. As to angle, that depends on application and fastener used in the countersink.
Do a Google on Weldon single flute countersink to find a distributor.
Bruce S.
I don't know if they're Weldon or another brand, but Lee Valley has countersinks in that style: http://www.leevalley.com/wood/page.aspx?c=2&p=32308&cat=1,180,42240,42281&ap=1.
I like them for deburring the edges of drilled holes by hand; they cut more cleanly than the traditional multi-edge countersinks.
http://www.eagleamerica.com Has them also. Part #365-9399.Work Safe, Count to 10 when your done for the day !!
Bruce S.
I have the Lee Valley set that Steve linked you to, and they've been great. I've used them in wood and in brass. One thing I really like is that the design makes it easy to CS a hole that's already been drilled, and be centered.
Edited 9/4/2007 12:03 am by forestgirl
