Hi,
I’m trying to build a hold down jig but I’m not sure what type of router bit to use for this task. I need to countersink grooves for a size 20 1/4 inch carriage bolt. (The base is counterbored for the bolt heads.) 5/16 inch slots for the 1/4 inch carriage bolts)
The jig I’m building is like the one shown in Kelly Mehler’s dvd Mastering your table saw. Title 3 chapter 4.
I have a 1/4 inch spiral router bit but I don’t think that’s going to be any good for making the countersunk grooves needed for the carriage bolts. It will be ok to plunge through the countersunk grooves though.
Help please!
Wanda
Edited 7/26/2005 7:34 pm ET by wanda200b
Edited 7/26/2005 7:40 pm ET by wanda200b
Wanda, What you need is a straight router bit and two temporary 'rails' to guide the router and center the bit over the slot.
Instead of 'Plunging', just gradually penetrate as you (at the same time) traverse the router forward. this will eliminate any tearout.
Of course, you'll have to 'Backtrack' a bit to remove the small 'Ramp left at the starting point. since you are using a 1/4" bit, and you need 5/16", just move the rails apart each 1/32".
Steinmetz.
Another vote for router. I used two straight bits, 3/4" and 1/4" (5/16" would be better but I don't have one yet) to make a t-bolt hold down recess on a couple of jigs. It was extremely easy and results were perfect.
Hi guys,
I'm going to have to see if I can find my edge guide. Otherwise I'll just have to find 2 straight pieces of wood to guide the router while counterboring.
Can I use a 1/2 inch dado bit for the counterbore? Not sure dado blades are used to plunge I've only used them to do dados for shelves. I need to look for a large straight bit. ( just finished checking out LeeValley) So it appears I'm looking for a straight plunging bit approx. 1/2 inch diameter. Should I pay a little more and get the 1 1/4 inch depth bit? Would it be better to use a Panel Pilot bit rather than a straight 1/4 inch spiral bit for plunging though the material once the counterbore is made? (never knew such a bit existed till I saw it on the Lee Valley website.)
Great pics routerman. Thanks
Wanda
Edited 7/27/2005 6:29 pm ET by wanda200b
Edited 7/27/2005 6:37 pm ET by wanda200b
I used one straight board as a guide/fence and routed carefully to pencil lines in one slow pass for the 3/4" recessed groove, then several shallow passes for the 1/4" through slot. Two boards would make it goof proof. I don't remember why I used just one. Routerman is the guru in this area. Whatever he says I would consider gospal.
Hi Ram,
You're right about making it foolproof using 2 boards. That way the router won't steer away from the edge guide. It will be supported on both sides.
When you cut countersunk grooves do you use a plunge router or fixed router? My countersunk groove starts in the middle not at the end of my workpiece. But the only router bits I have are spiral 1/4 inch and a dado 3/4 inch diameter bit. Not too sure about using a dado bit in a plunge router to make this kind of a cut. Think what I need is a plunge straight router bit.
Yes, I have to agree with you. Routerman is the expert when it comes to routering. Only routering experience I have... dadoeing, (bookshelves) trimming, rounding off corners (adirondak chair) and cutting gooves for drawer bottoms. The router is my 2nd favorite tool in the shop next to my Table saw. :)
I don't claim to be an expert, so keep that in mind. This particular operation went so well I am confident I understand it.
I believe it will be confirmed by more experienced folks that you should avoid using a fixed router for plunge operations such as this. It's fair to say anytime you lower a spinning bit into the work it is a plunge operation, and I did it with a plunge router. I would not feel safe doing this with a fixed base handheld, but on a router table would not be worried so long as the long edge of the workpiece had adequate fence contact.
Hi Ram,
I never intended to use my fixed router to make the countersunk grooves. I have a plunge router for that. Sorry for the confusion.
Wanda
You may be at risk here, Wanda.
Email pat@patwarner.com for some details if you'd like.
If you'd like to post analysis, I would have no problem.
If the shape you are looking for is as per the attached, the easiest way to get the slot and countersink on the same axis is to use one fence and two bits. The first the width of the countersink, and then follow up with your 1/4" bit on the same fence setting. Guven a choice, I would size the top slot to take a washer under the head of the carriage screw, this will significantly increase the life of the jig.
David
I think this picture is an example of what you're after. The rest of the link will give you some idea how to get there.
Hi,
Routerman, I clicked on your link (picture)... that is a wonderful pic of a countersunk groove. Just what I am attempting to do. I need to know what type of router bit that is on the left hand side.... The router bit on the right side is obviously a straight 1/4 inch bit by the look of it.
Thanks for the links.
wanda
