Can anyone comment on this Craftsman 12″ drill press? I will mainly use it for drilling out the bulk of mortises. Should I be concerned about the LCD longevity in a shop with no AC or heat? I have compared similarly priced Delta’s with only 1/3 HP. The Craftsman has 2/3 HP. Thanks in advance.
The LCD will likely last as long as that machine, and if not it's easily replaced. The 2/3 HP motor is likely overrated. A true 1/3 is plenty for that machine.
Whatever you get, you'll quickly find you use it for all sorts of things.
Pete
Edited 10/31/2006 6:46 pm ET by PeteBradley
Will that 12" Craftsman be suitable for drum sanding or will I need to step up to a larger frill press?
I don't know how solidly this machine is constructed, but regardless of the machine I'd expect it's ok for occasional sanding. The bearings in these machines are commonly the same ones used for radial loads anyway. If you're going to do a lot of sanding or heavy sanding with tall or wide drums, a drill press isn't a great choice.Pete
Edited 11/2/2006 12:30 pm ET by PeteBradley
It's not the bearings that can't take the radial load, it's the morse taper that is not designed for radial loading. Side loading causes it to work loose while end loading causes it to get tighter. If thre drill press has a screw on chuck that screws directly to yhe quill shaft without any morse taper involved then side loading is usually not a problem.
RichThe Professional Termite
Yeah, I knew someone was gonna bring that up. That's where I was going with light sanding and small drums. Maybe I'm just lucky, but I haven't popped a taper yet.
I don't know for sure, but I think it's unlikely that a Craftsman 12" is going to use a taper anyway.
Pete
Edited 11/3/2006 9:21 am ET by PeteBradley
Hi Trialnut,
I never new that - makes good sense, though. Thanks for the information.
Mike D
Try to look at the owners manual before you decide.
The manual on my 16 inch Craftsman says no drum sanding allowed.
Mike D
