I have just gotten my shop back in order after a move from the North to florida. I recently purchased some Cherry wood for a project that needs to be milled. I rescued my planer from my Son and am going to surface the faces but can’t remember how I went about squaring up the wood.
We have a few videos on our site that describes the milling process. Basically you flatten one face on the jointer, plane the other face parallel to the first face. Joint one edge 90 degrees to your flattened face. Then rip the final edge on the tablesaw.
Here's Gary Rogowski's approach. He's a pro and an entertaining teacher.
http://www.taunton.com/finewoodworking/subscription/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=5293
Here's a version I produced with Asa Christiana for our series Getting Started in Woodworking. Once you click on the link, scroll through the playlist to view Episode #9.
https://www.finewoodworking.com/start
If you don't have a jointer, write back and I'll address your question with another solution.
Matt Berger
Fine Woodworking
I do not have a jointer but a planer and a never used jig with aluminum railing to use my router on the edge.
Okay. In that case, here one suggestion:1. Flatten the first face by running the board through your planer using some type of sled like the one described here and in the accompanying video:http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=24118You can simplify the jig by just getting a flat board with a stop on the back and shimming the piece with tape and thin scrap pieces.2. Once the first face is flat, then run the opposing side through the planer. 3. With both faces flat and parallel, use your router jig to trim one edge 90 degrees to the flat faces. You can do this without a jig, just install a straight bit and run the router along a straight fence to trim the edge of your board.4. Use your tablesaw to square up the final edge.Let me know if you have any more questions on this.- Matt
Thanks. I reviewed that video yesterday. Going to start on it tonight.
Just wanted you to know that I created the sled you mentioned and completed the two faces and this morning set up a flat board to rout the edge. Everything worked fine. Thanks.
Excellent. Glad to know the advice paid off. Keep us in mind with your next question!
