I am using a black nitro lacquer finish on a table. I am trying to match a set of chairs that have a dull (somewhere between a satin and flat) texture. I have used both rottenstone and 0000 steel wool and need the finish to be a little duller. Is there anything I can put in the finish or an alternate way to buff the surface to knock down the amount of gloss? I guess I would like to be able to get more “adjustment”. Both the rottenstone and 0000 steel wool still give too much “gloss”.
I know nothing about using black lacquer, but you might try 4F pumice or even 2F. To even out the shine, or lack of shine in your case, I would use some kind of rubbing lubricant ( soapy water?) Some of the synthetic abrasive pads could also help dull your finish.
The simplest solution is to spray a coat of matte lacquer over the black.
An alternative rubbing method is to use Mirka'a "Abralon" abrasive disk with your random orbit sander. The Abralon comes in a variety of grits for a variety of sheens. It takes a lot less "elbow grease" to let the RO sander do the work.
Paul
F'burg, VA
The next step would be 600 w/d paper using oil as a lubricant but that will likely leave noticible surface scratches. They would be very fine but would not be the dull effect that you are looking for. What you need to do is add a flattening agent to the paint then recoat the pieces. Your paint supplier should be able to guide you in preparing the mixture.
Steve - in Northern California
