to all, there was an article some time back on how to build various types of crosscut sleds for the tablesaw and i can’t find it in my incomplete collection or in the archives or the magazine index. Anyone remember the issue it was in? i would greatly appreciate any info on the subject. thanks, pete
Pete,
I did a search on the home page here...Jan-Feb. 98 #128 has an article on sled building. Also, there is a video clip on fine tuning your crosscut sled which might be useful to you too...just do a search on the home page...
Look in the index for American Woodworker at their web site.
I don't know about the issue Buttttttttttt
If you want a very strong accurate and good design crosscut sled check this one out-
I built one at the cabinet shop to replace the old junker they had been using on one of the unisaws. Everyone loves it's square cuts -
I also put a thin metal ruler inset on the right side of the blade to the edge of the sled- you could get fancy and make it adjustable- " I use it to square up door panels"
I found this plan at Highland Hardware site the plan has a Great way to set the fence to get PERFECT square cuts.
You will love it. http://www.tools-for-woodworking.com/slidingtable.pdf
Ron
Who Ever Has The Biggest Pile Of Tools When You Die Wins
Kelly Mehler has a nice one in his book and video
Darkworksite4:
Estamos ganando detrás el estado de Calif. Derrotando a un #### a la vez. DESEA VIVO LA REVOLUCIÓN
Steve latta describes an assortment of sleds in Issue #160, pages #104-108.
HTC makes one for sale. Nice melamine unit. Very accurate out of the box with all the bells and whistles.
Boris
hey Matt, that was exactly the article i was looking for. good thing it didn't have teeth cause it was right under my nose and i missed it . thanks a lot. pete
What I did was to lay two oak slats into the miter slots and glue a piece of 1/2" plywood onto them. The slats were 3/8" thick and slightly under 3/4" wide. Then I ran the saw blade almost all the way through the plywood and used a carpenter square to set the back guide board. That was glued on with screws from the bottom. The back guide board was 4" tall and 2" thick so as not to be cut into by the blade. I also put a similar board onto the front. The slats on the bottom was waxed heavily for lubrication and to minimize expansion / contraction from humidity changes.
I also later marked 45 degree lines on either side of the kerf to facilitate cutting frames. Frame pieces can be held down with scrap boards screwed to the plywood.
PlaneWood
