gentlemen:
I glued up a red oak panel that cupped.
to get the cup out I laid the panel on two strips of
wood and a cinder block on the center,which worked.
My question what to do to prevent the panel from cupping
again?
gentlemen:
again?
Leom,
This article may help you:
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=2634
Try using cauls. They should keep your boards from cupping. It is also important to edge your boards with a sharp jointer. The more open pores on the surface, the better the glue-up. A dull jointer clogs pores and prevents this.
Please write back with any other questions.
Sincerely,
Gerald
