I saw an example furniture online and really liked how they curved the rod on the chair. I was wondering how do you usually go around doing that? I know steam bending is one option but I think there must be an easier way to get around with this.
Thoughts? Would be great if you have some resource that teaches you how to do this as well.
That doesn't appear to be steam bent, the radius are too tight IMO. On close examination I think it was assembled square and then profiled. You can see different coloring in the wood at the corners. I think you could assemble the frame square with mitered corners then route the profile using a large diameter round over bit, but it might be a bit of a white knuckle experience with home shop equipment. A commercial CNC probably makes short work of that and safely.
What esch said. Straight parts, with lots of options to do final shaping. Definitely not steam bent.
