Custom Shaper cutters or router bits.
Hey folks,
Anybody have some suggestions to have some bits cut?
I am doing a reproduction and it is just taking forever to mill the molding when I have to make 5 different set ups and passes.
I have some finished Molding I could send them as a pattern
Hi repairman87 ,
Depending on whats available in your area you might check with some of the saw sharpening shops for making custom cutters for you .Also just a thought check with a local mill working house or shop , see if they have the ability to run the stock for you .This certainly would cost you to have them run it for you , but by the time you have custom cutters made and spend your own time and labor to run it also , there may be little actual difference . The way I see it you could be productive in other money making ways while the other guy runs the stock for you , maybe .
good luck dusty
Where are you and how old is the original moulding? There's a place here in Milwaukee called Bliffert Lumber that specializes in old profiles. If it was a common one when the place was built, they may have access to it. Maybe you could draw the profile on paper and fax it to them. Their phone # is 414-383-4900
check out http://www.magnate.net/
they have a large number of quality bits (both shaper and router bits)
and can and do make custom cutters.
check them out!
Charles Schmidt Co. makes custom cutters.
http://www.cggschmidt.com/index.html
Good luck.
