Cut out for Router Lift (Jessem etc.)
Hello Folks,
What is the best way to rout out the area to drop a router lift plate into to get the exact, snug fit. ( I have finished an arborite on 3/4″ mdf table top and it is waiting for a new Jessem). I have never used following guides on a hand held router..(Freud’s following guides seemed to be in my price range). Is This the way to go? And how?
You usually can get a router template for the specific router lift you are looking to buy at the time you purchase the lift. They normally come with instructions. It's easy...
Drew
Thanks Drew. I will see if the supllier had anything.. I guess they have an interest in not telling us so they can sell one of their ready-made units. (All very nice but very pricey)
I also vote for using a template if possible as it is the easier way out. However, if a template is not available or you want to do this now, see the link below for a story on installing a lift plate. Before templates were so common, I had to figure out an accurate way of doing this.
http://www.newwoodworker.com/instrtrlft.html
Tom Hintz
Because there is always more to learn!
Thanks Tom
Your article lays it out very clearly. I can't wait to get started tonight !
Jessem does make a template for their router table plates. Available at http://www.eagleamerica.com In the search box put in the part number 415-6503. Hope that helps. Yes, I do work there but just want to be helpfull.
Bruce S.
That looks pretty simple , thanks
Lay the lift face down exactly where you want it to be in the future table. Completely outline the lift with cutoffs that are all the same thickness and wide enough to balance a router on top of. Fasten the cutoffs down with a few brads. Remove the lift from inside the frame. You are now left with a negative of the lift. Set up a plunge router to go that exact depth (using the actual face plate as a gauge). Route out the footprint using a bearing guide. You can cut out the void to let the lift through the table using a similar method, a jig saw, or a sawzall.
Estimated Time: 15 minutes (If you have four proper cutoffs available)
Edited 8/27/2007 4:50 pm ET by MattInPA
John White illustrates this technique in FWW #153:
http://www.taunton.com/finewoodworking/Workshop/WorkshopPDF.aspx?id=2758
Yes, But how do you handle the corners? Getting the right radius? Aside from using a monster pattern bit. Work Safe, Count to 10 when your done for the day !!
Bruce S.
I don't have a Jessem, I have a bench dog. the radius of the corner was similar to the router bit that I chose (probably only 1/2"). Are the Jessem's corners that round? I can't imagine that it's worth the money to buy a pattern that will only be used once. My corners aren't perfect, but they filled in with saw dust after one use. Nothing gets caught on them or stuck in them. I personally wouldn't pay extra for that jig. I'm sure, however, that I own a few things that people question why I bought it. Check ebay first. People that buy these must want to unload them. You could even post a message here that would attract owners' attention. People may not put them up on ebay because they think they'll only get $1-2. offer 50%.
Woodworking at home had a show where they pocket holed two 1by3 the out side can be longer the inside boards are cut the with of the plate plus the router to the bit. twice clamp it down and go bare in mind the radius of the corner of the plate and chose the bit accordingly then cut out the center with a jig saw.
