Hi
Just coming to grips with cutlist 4 plugin for sketch up.
If I am using 2 different stock sizes for a project i.e. 1*4 and 2*4 can I get cutlist to use the appropriate stock for the component required if I select all the components.
At the moment it is defaulting to the larger of the two sizes for all the parts.
Perhaps selecting the appropriate components for the stock and producing two different layout reports is the only way.
cheers
John
I don't seem to have any problem with with it. I tried a sample with a board drawn as 2x4 by some length and another drawn as 1x4 by the same length. Both components were listed in separate lines in the list and the layout showed the pieces laid out on two different boards. If you'd like to send me the SKP file, I would take a look and see if I get different results.
Dave
