Cutlist Software for Custom Cabinets
Based on Microsoft ¯ Excel
Woodworking Cutlist Software for Custom Cabinets, Doors and Drawers
Project Planning Tools Designed for Cabinetmakers and Woodworkers of all Experience Levels!
________________________________________________
Calculating cutlists for custom cabinets, doors and drawers can be tricky and time consuming. Miscalculations are often discovered after the components have been cut which results in extra cost and lost productivity.
CabinetCRUNCHER, DoorCRUNCHER & DrawerCRUNCHER are designed to simplify the project planning process and eliminate mathematical errors so that you can plan and build your project correctly – the first time!
You’ll be surprised how easy it is to create a complete cutlist and list of materials from scratch in minutes! These project planning tools are easy to use and flexible enough to support a wide variety of custom cabinets, doors and drawers.
Get Organized, Save Time and Eliminate Costly Mistakes!
CabinetCRUNCHER, DoorCRUNCHER and DrawerCRUNCHER are a collection of 76 different spreadsheet programs based on Microsoft ¯ Excel. Each spreadsheet is designed to calculate the exact dimensioned size of each component of your project and the quantity of all your materials!
Simply select a desired cabinet, door or drawer configuration from the main menues and the software will link you to an appropriate spreadsheet template to input your specifications.
In just a few minutes you will have a complete cutlist that will calculate the exact size of each component of your project and a list of materials that will calculate the total quantity of stock you will need.
Your cutlists will also include fabrication and assembly notes that will guide you in the shop. These notes provide information regarding the location and depth of rabbits and dados, face frame positioning, door and drawer schedules/overlay requirements, requirements for mitered edges, and other features that are required during the fabrication and assembly process.
The software includes an Illustrated User Guide and helpful pop-up comments along with links to illustrations to help you customize the project to your specifications.
CabinetCRUNCHER, DoorCRUNCHER and DrawerCRUNCHER can be operated on any PC or Mac that has Microsoft ¯ Excel 97 or later versions installed.
Create a Complete Cutlist & List of Materials for your Project in Minutes!
___________________________________________________________
CabinetCRUNCHER â„¢
Create cutlists for almost any configuration of free-standing base cabinet, wall cabinet or bookcase.
- Includes 46 different cabinet configurations that can be customized to any size or style!
- Build individual cabinets or combine cabinet configurations together to build custom kitchen cabinets and islands, vanities, storage and utility cabinets, bookcases, built-in furniture, hutches, entertainment centers, dressers and many other custom woodworking projects!
- Supports a variety of common construction techniques: You can build build face-frame or frameless cases using rabbits, dados, biscuits, or pocket-hole joinery
- Excellent customization capability: Customize your cabinet by adding special features such as end panels, mitered or revealed edges and corners, recessed back panels, fixed or removable shelves, fixed or removable bases and more!
- Get more information, screen views and check out the User Guide at www.cabinetcruncher.com
DoorCRUNCHER â„¢
- Compliment your cabinet or woodworking project with perfectly fitted doors, drawer fronts & custom end panels!
- DoorCRUNCHER makes it easy to build virtually any style of flat or raised panel door configuration
- Build any style of single-panel, two-panel, three-panel, four-panel or six-panel door
- Build either overlay or inset doors using common tenoned or mitered rail and stile construction methods
DrawerCRUNCHER â„¢
- Finish your project with custom drawers and slide-out trays designed to your specifications!
- DrawerCRUNCHER provides the flexibility to build virtually any style of drawer or slide-out tray
- Select from a variety of joinery options: Standard Box construction, Through and Half-Blind dovetail joints, Rabbit & Dado or Locking Miter joints
- Get more information, please visit www.cabinetcruncher.com
Great Value and Affordability!
Purchase a fully integrated version of CabinetCRUNCHER, DoorCRUNCHER & DrawerCRUNCHER together at a great Introductory Price!
Try it out today with a 30-day, risk-free, money-back guarantee!
Get more information and screen views at www.cabinetcruncher.com. If desired, you can download a fairly large Adobe .pdf file that includes screen views of each of the menu screens and examples of cutlists for each of the 46 cabinet and bookcase configurations, 21 door configurations, and 10 drawer configurations.
Thanks for sharing.
