Cutting a cylinder lenthwise
I have spindle- turned four 2.5″ diameter cylinders 36″ long. I want to cut each cylinder lengthwise into four pieces. Thoughts on how to make the lengthwise cuts?
Cutting cylinders
I am no expert on this process but as you've not had other answers (I suspect problems with the site is the cause) I'll give it a shot.
I would build a "container" to capture the cylinders. Then, using the edges of this container as a guide for a circular saw, go to work.
Frosty
I cut 100 baseball bats in half for a sports bar APRON from bar top to base. I didn't do 1/4 cuts. jsut in 1/2 but I think my method will yield your desire.
Draw your desired cut on the cylinder blank, put a tall splitter behind and CLOSE to your band saw blade 1./2" mininum blade width for the task. The "splitter/riving knife" will hold the off-cut still perpendicular to the table surface. Worked a treat for me. The cut surface is not glue quality/band saw reveal.
Yes, the job was done on the tapered baseball bats by eye and following a scribed line. Somple, a monkey could do it. I even took the 1/2 ball bats blanks to the jointer and smothed the cuts. I don' think this is an option for you. You desiire 1/4 cuts.
Happy Holidays.
DonC
cutting cylinders lengthwise
Have you thought of gluing up 4 pieces of 1.5" X 1.5" X 38" long wood with newspaper in between the 4 glued up pieces. Turn your bat normally to your 2.5" dia X 36 "size. Next, take a chisel and split the piece at the end along the newspaper glue line. You will have 4 perfectly matched 1/4 pieces of bat.
