Just bought one of those 4′ heavy duty multi-system fences from Woodworkers Supply. Nice piece of metal. I want to cut it into 2 pieces. 18″ and 30″. What blade would you use on the table saw? Would you do it in one pass or several?
ASK
ASK
Use a carbide-tipped blade with a negative hook. It can be cut in one pass, but if the aluminum is thicker than about 1/2", two passes would be easier on you and the blade. Be sure to wear full face protection.
jackplane,
Always wear face protection. It is about 1/2" and L shaped. I'll probably do each leg separately.
thanks
ASK
To add to what Jack said , apply either wax lube or even parawax to the blade before cutting
jako
thanks
ASK
I would use a hollow ground plywood blade ... preferrably a cheap 7 1/4" blade (if that will fit on your saw). Do use a cutting wax to lubricate it (WD-40 or regular paste wax will do in a pinch but regular cutting wax is better). I have cut many large aluminum I-beams and even lots of aluminum sheet metal this way with just a portable circular saw (skillsaw). I used to gang cut stacks of soffit metal this way, and aluminum awning pans etc. The many small teeth of the plywood blades are much safer (cheaper too) than the large carbide teeth. They will not last forever but you have only one cut to make.
ASK, any old carbide wheel and some soap or a candle for lube. I used to cut lots of thick brass/bronze and aluminum on my Craftsman by making multiple passes. Wear an apron tied up close to your chin and use a face sheild (Those hot pieces of metal sting.) Steinmetz.
That one blade became my dedicated non- ferrous cutter wheel after somehow ??? one whole tooth had been knocked off my 60 tooth forrest blade. To rebalance the blade, I removed three other whole teeth # 15 , # 30 , and # 45.
Still have the blade and use it for phenolic. If you don't mind my asking , Ask, why not use a hacksaw? A Sawzall? or, a metal cutting blade in a saber saw?
If, the shape is angular, (Ell shaped) insert or tape a short sacrifical block of wood to the area of the cut to prevent snagging of the teeth.
Band saw?? Chopsaw? Signed : ED REPLY
Edited 10/16/2004 6:30 pm ET by steinmetz
Steinmetz,
I can probably find an old carbide wheel floating around somewhere.
I want to use the table saw because if want the cut to be straight and square.
I will probably do the cutting tomorrow. I let you know how it comes out.
Thanks for the advise
ASK
I recently bought an Accusquare fence for my garage saw and didn't have room for a 48" rail in the place I wanted to park it. I cut it on my bandsaw with an old 12t wood blade I had. I took it slow and got excellent results. I know you probably don't have a bandsaw to cut the length you need ( I sure don't ) but the ease with which it cut was a pleasant surprise.
les
Ok here is the result.
Successfully cut the 48" piece into 1-30" and 1-18' piece on the table saw. Several passes. No problem.
But here is the problem. the Inca miter gauge which I intended to use with these pieces does not have enough height to meet the slot at the back of this extrusion.
So, I am going to have to cut off about 1/2" along the bottom lengthwise.
I'll let you know how it comes out.
And again thanks for all your suggestions
ASK
