I am a carpenter in ohio. I am looking for a use for short leftover peices of hardwood. My latest idea was, cutting boards, laminating 1 x 2 pc together to make 20 x 13 blank. Then running it through the planer. I have tried it with oak, maple, mahog, and cherry. they look pretty good . My question is this, is there some type of sealer or oil I should be sealing these with? I want to use them as gifts.
I use walnut oil bought from the grocery store. Put it on, let it soak in,wipe it off. Easily renewed and non toxic.
Or, mineral oil. A hard coat, like shellac, is safe but I wouldn't use it. Walnut or mineral oil is best.
Shellac will be "cut". Use mineral oil. Other nut or veggie oils will go rancid. And there is always a possibility of allergies.Gretchen
right. shellac will be "cut" but it is safe, and is already a food covering for many foods.
You can safely use any finish--once it's fully cured (roughly 30 days)--but practically it should be an oil finish so it doesn't build on the surface.
Mineral oil doesn't cure, but is often used. Sometimes with wax. Nonetheless it wouldn't be my choice.
Not so sure I like the use of oak & mahogany in cutting boards because open pores can harbor food material.
I have used tried and true danish oil. It works and looks great but takes a while to dry.
I make a few cutting boards every year for Xmas presents for good customers. I use the scraps from whatever projects I've done over the year and usually buy some "exotic" wood to give them some "pop".
I use mineral oil for a finish and also tell the recipients that they're intended more for show (setting out cheese, crackers, etc at a party) than day to day use.
For "real" cutting boards, I stick to maple with a mineral oil finish. I like mineral oil because it's readily available and easily applied with a cloth or paper towel.
I just put together an oak and maple cutting board (then read all about how you shouldn't use oak, ash, mahogany, etc. - oops. This one will be for raw veggies only I guess). Anyway, I applied mineral oil and the maple looks great. The oak looks good too, but I think the open pore structure of the oak allows it to maintain little oil resorvoirs because anytime you wipe the board with the grain it seems to pull out just a slight amount of oil from the oak pieces. I don't think this will cause a problem in the long run, but I'm definitely going to need to give it a thorough wipe down to pull all that extra oil out of the oak pores. On the other hand, the maple just wipes on, absorbs, wipes off, and looks great!
