I’ve been finding conflicting information about the appropriate wood to use in making cutting boards. Maple seems to be the most popular, but I’m trying to figure out if Walnut, Hickory, Cherry, or Red Oak would have the appropriate grain structure for the project(s), or could be used to contrast the hard maple? Any insight?
Also, everything I’ve read says that mineral oil is the way to finish and cure them. Would boiled linseed oil work just as well? (I’m having a hard time finding mineral oil in the local stores.
Thanks.
MAPLE, BIRCH & CHERRY
As Dense Grained Woods Are Suitable For True Cutting Boards
True Cutting Boards Are Boards That Can Handle Meats < Chicken Etc.
LITE Mineral Oil Is In Every Drugstore In North America
Apply Once A Day For A Week
Once A Week For A Month
Once A Month For A Year
Then Yearly Touch-Ups
Wash Board In Sink Not Dishwasher
Use Tite-Bond 3
Hi Jim, it sounds like you already got some information on this. If you're interested in other resources, check out the links below.
Good luck with your project,
Gina
FineWoodworking.com
The Wood Whisperer has a video on making a cutting board: http://www.taunton.com/finewoodworking/ProjectsAndDesign/ProjectsAndDesignArticle.aspx?id=28480
Tim Albers wrote an article on making them:
http://www.taunton.com/finewoodworking/ProjectsAndDesign/ProjectsAndDesignPDF.aspx?id=29510
And here are two pieces of content on food-safe finishes: an article: http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=26893
and a video: http://www.taunton.com/finewoodworking/Materials/MaterialsArticle.aspx?id=28481
Thanks, Gina.
I reviewed the articles you cited. (I'd already seen them.)
I ended up making it with alternating strips of hard maple and cherry.
In terms of the finish, I ended up using Watco's Butcher Block Oil and Finish. I tested it against straight Mineral Oil and thought it brought out the grain and color of the cherry better. The label says it food safe and all that, but I'll have to wait a while to see how well it stands up.
Thanks again.
Jim
Glad you found the info you needed for your project!
