I need to make two cuts on thin copper (Plus or minus .020) sheets, and being only of the wood persuasion, wonder if I can do this on my bandsaw. The requirement is to cut about 1/4″ off two pieces about 6″X14″. I don’t care about damage to the blade, since I have a genuine original that came with my 14″ Delta and probably won’t use it again anyhow. Any advice would be appreciated.
Bob... Most bandsaw blades will tear up the edge something awful. Invest in a pair of 'tin snips'. They are the scissors used to cut metal. If you really want to use the bandsaw, put on the finest (high tooth count) blade you have. Next, sandwich the metal between two pieces of wood and cut through the whole sandwich. the lower board will properly support the metal so it does not bend or rip. SawdustSteve
I have some tin snips, but past experience says I usually end up with kinks and bends when I use them. Do you think I am better off with snips as opposed to using the bandsaw with the copper held between a couple of pieces of 3/4" plywood?
Cutting copper will not hurt the blade. Just cut slowly. Draw your cut line on the copper, and support it with 3/4 or 1/2" wood or plywood. Then hold a piece of wood/plywood right next to the cut line on top of the copper and start cutting. That way you can see what you're doing, and the copper sheet will not move around. I do this all the time with copper, brass and aluminum. Remember--cut SLOWLY; otherwise the blade will grab the metal and tear it.
Thanks for the advice. I had another thought and tried it on some scrap copper. I made a sandwich of a straightedge, copper and plywood. Then I scored the copper along the straightedge about ten times with a utility knife. After that, I put the edge of the copper to be cut off in a vise, which happened to be the same length as the piece of copper, and snapped it off. It worked quite well. Now I'll try the wood/copper sandwich in the bandsaw.
Isn't it interesting how often that discussing a problem with somebody else helps, even though you may not use the advice received?
Thanks #2. I tried the plywood, copper sandwich and it worked like a charm. I was able to cut an eighth of an inch off each side, leaving a very smooth cut. Now, as to the condition of my Timberwolf blade, I guess I'll find out the next time I try to cut a piece of cherry with it.
Bob
how about that sandwich and a router and a flush trim bit??
That would probably work too, but I avoid things that go around at 20,000 RPM whenever possible, and it's possible. Maybe when I grow older.....
point taken. good luck regardless, ....bear
"expectations are premeditated resentments"
You can cut copper, aluminum and brass with woodworking tools. Won't damage the tools but might not give you the best cut. Cutting non-ferrous sheet metal between pieces of ply will almost always give a good cut, regardless of the tool used.
Thanks for your thoughts. I did just as you suggested, made a plywood sandwich, and sliced an eighth of an inch off each side with a very smooth cut. Just a quick touch up with 120 grit sandpaper was all that was required.
